Failed to create a Python-based process during because Python scripting is not supported.
If FIPS mode is enabled, consider turning off FIPS mode by using 'configure security fips-mode off'. If FIPS mode is disabled, consider turning on Python scripting by using 'configure security python on'.
Error
Failed to create a Python-based process %process% because %reason%.
| Name | Type |
| process | String |
| reason | String |
